Track bar Question
Old Dec 22, 2011 | 02:47 PM
j33p4life's Avatar
Default Track bar Question
I have a 08 with 3 inch lift. I have read plan mans DW thread and believe its my Track bar. if its gone bad and oval as people say can I just replace with a used stock one? what's a good price on one of them? thanks!
Old Dec 22, 2011 | 03:30 PM
JKred's Avatar
First, you would want a adjustable one with 3" of lift. Second, you need to check the mounting bracket holes, not the bar ends. they are the most common for ovaling out.
Old Dec 22, 2011 | 03:32 PM
j33p4life's Avatar
ok not around it now but if it is then I need new bracket too? and that's all?
Old Dec 22, 2011 | 03:35 PM
MossGaBoss's Avatar
You could actually weld some heavy washers in to round the holes out again.
Old Dec 22, 2011 | 03:36 PM
j33p4life's Avatar
I am in highschool so no way to get to a welder and have no idea how...
Old Dec 22, 2011 | 03:57 PM
Lilahs Jeep's Avatar
If you have a high school shop class. Talk to the shop teacher about having someone weld it up for you.
Old Dec 22, 2011 | 04:00 PM
j33p4life's Avatar
I would be he is an ass and wouldn't let me... haha is it hard? I have a friend who owns a welder and is pretty good...
Old Dec 22, 2011 | 04:19 PM
Jknockers's Avatar
Yeah, just check it out by pullin the track bar bolt down on the axle and inspect it. If oval, get some 9/16 flat washers and have your friend weld them on each side of the bracket and then get a longer 9/16 shouldered bolt (grade 8 if you can find it) and torque that sucker to about 125 ft pounds when you tightn it. Also make sure you don't shank the nut on the shoulder of the bolt before it tightens down. Ya might have to use a lock washer on the nut so ya dont shank the nut on th shoulder of the bolt.
Old Dec 23, 2011 | 05:15 AM
MossGaBoss's Avatar
Where I live, and that may be different from where you live....you could get that done at a welding shop for 30 bucks or so.....may even try a muffler shop, most of those guys can weld if you don't have a bonafied welding shop in town....good luck with it.
Old Dec 23, 2011 | 06:33 AM
j33p4life's Avatar
Ok thanks everyone! this has helped a ton! I am going to look around and find a welding shop! so I have them weld a couple heavy washers on top and bottom? and then what else? a new bolt that goes in their?
