Track Bar Question-Need Opinions
Old Dec 31, 2007 | 07:30 PM
nukeman's Avatar
Default Track Bar Question-Need Opinions
Looking to purchase front/rear adj. track bars. I was curious if any of you have any experience with the following brands or had any recommendations.
Superlift
Black diamond
Rusty's
They are all in the $130 range. Is the quality OK or is it worth it to go with the more expensive brands like TF or JKS?
Old Jan 1, 2008 | 07:42 AM
AZJeeper's Avatar
Community Favorite
I have the Black Diamond front and rear. No experience with other brands, but the BD's seem beefy enough and are easy to adjust.
BTW - Black Diamond = Superlift (exact same part).
Old Jan 1, 2008 | 09:45 AM
rickl's Avatar
Default Very happy with teraflex
originally ordered black diamond,showed up as naked bar,no hiem joint or bushing,sent back spent alittle more ordered teraflex,very happy with it,easy to adj.lots of flex and no bump steer with my 3" system and stock draglink/pitman arm,all of my suspension is teraflex,had black diamond front springs too stiff+didn't sit straight
Old Jan 1, 2008 | 03:21 PM
nukeman's Avatar
Thanks for the info. I was VERY close to going with the Tera bars, but had a coupon for 4WD.com (forgot about it). So, I went with Full Traction front and rear. $324.00 for both. Never bought anything FT before, so we'll see.
Also ordered the Daystar dash, Pro Comp light bar, Mopar slush (floor) mats and Mopar side step/rails. It was an expensive night for me
Old Jan 1, 2008 | 05:55 PM
NE Wrangling's Avatar
I saw they had a pro comp adjust front track bar. Let me know how you like the FT as I'm planning on getting a set also and I'm leaning to the Ft heavy duty.
Old Jan 1, 2008 | 06:54 PM
nukeman's Avatar
I saw the Pro Comp too. I have had 2 Pro Comp lifts in the past on 2 Silverado's and they were great, no problems. I just wasn't too sure about the angle of the Pro Comp track bar. Maybe it's better, who knows, I do know that the Full Traction is gusseted around the end joints and appears beefier. I'll let you know how they work out.
Old Jan 1, 2008 | 06:59 PM
Thanks as I think this is what WOL is running or maybe it's the lift kit all together.
Old Apr 18, 2008 | 06:31 AM
RedneckJeep's Avatar
I like the teraflex bars. they look tough and very well made. Probably won't be what I use, but I like the way they look.
Old Apr 18, 2008 | 07:03 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Originally Posted by rickl
cannot keep teraflex front track arm tight,clearance issues in upper mount under severe flex,gonna tear mount off.changing to rubi express severe duty with drop/reinforce bracket+high steer drag link,also tera flex rear track arm drop bracket,caved in my rear shock under full compression(thank christ just had cheaper shocks on and havent upgraded to resi's yet.gonna change to adj track bar with raised lower mount.no problems with tera flex upper+lower control arms or rest of components though.13 month old vehicle currently reworking 3rd suspension configuration,only in a jeep,it's a damn addiction
Which rear trackbar bracket did you have?
What was loose on the front track bar?
Old Apr 18, 2008 | 07:07 AM
SilverBak's Avatar
Default Go Teraflex
Superlift
Black diamond
Rusty's
To be honest, you get what you pay for. In my opinion, you can not go wrong with any of Teraflex's products. They have some really beefy track bars that you will never go wrong with and will never regret buying!!!
