Track Bar and Shocks
Old Feb 11, 2012 | 04:54 AM
GCCIV's Avatar
Default Track Bar and Shocks
I hope this is the correct area first time posting...I believe I have a 3" lift on a 07 jk recently my track bar tore completely off from the axle housing and my shocks went out. I bought a bracket and rewelded it on the axle and reattached the trackbar. Put 2 new shocks on as well. However ever since everytime I hit a bump or even a small dip it feels like I bottom out the body feels like it slams on the frame...i recently saw a truck with double shocks on each wheel area whats the point of this would it help? Thanks for your input...
Old Feb 11, 2012 | 12:06 PM
highwayman's Avatar
Any possibility you added a bracket that raised the mounting point of the TB? If so it may be hitting the frame w/out enough bumpstop. Check the area above the TB at the frame to check for interference. Other then that the only thing thatd come to mind would be shocks too long.
Double shocks at each wheel, might as well have them chromed too. Meaning, no reason other then looks (80's I might add).
