Trackbar
Old May 4, 2009 | 09:22 AM
hohokom's Avatar
Default Trackbar
In order to install an adjustable trackbar, do I only need to get the rear axle off the ground and install the new adjustable trackbar? What measurement do I take to know how to adjust for centering?
Old May 4, 2009 | 10:17 AM
bly109's Avatar
Originally Posted by jgarner
You will not have to get the axle off the ground at all. It will have to be done with the tires on the ground. You will need to do some measurements before you start and see how far you are off right now. Then you will want to adjust you new track bar to half of that measurement and install. It is good to have a friend so that can push on the Jeep to get it to line up or use a rachet strap to pull the Jeep over.
x2 thats how I did mine.
Old May 4, 2009 | 10:22 AM
roguejk's Avatar
look at the di-it-yourself alignment thread and it shows you how to measure from both front wheel wells then you adjust accordingly.
