Trackbar help
Old Oct 29, 2011 | 09:01 PM
jeeeep's Avatar
sorry not familiar with FT install, trying to look at parts and make suggestions - the front and rear track bars didn't get swapped?
I noticed the hoops are close but the rear looks liek the hoop is closer to center.
I don't think you should be close to end of adjustment to get it centered.
Also, heim joint set at the frame end?
Old Oct 29, 2011 | 09:10 PM
dmick33's Avatar
The hiem joints are on the axle ends.
dmick33's Avatar
There is too much difference to have the front and rear swapped.
Old Oct 29, 2011 | 09:12 PM
jeeeep's Avatar
Is it possible to flip them and put the heim joint to the axle end?
Old Oct 29, 2011 | 09:14 PM
dmick33's Avatar
The hiems are at the axle ends and they can't be flipped.
Old Oct 29, 2011 | 09:31 PM
jeeeep's Avatar
just found write-up from WOL, this may help more than i can:
http://project-jk.com/jeep-jk-write-...3-economy-lift
Old Oct 30, 2011 | 06:56 AM
dmick33's Avatar
That's what I used to put on the lift but they just didn't line up with them on. Cup of coffee then back to garage.
