Trackbar help
I put front and rear JKS adjustable trackbars on my jeep. I noticed when I put the front one on, the diameter of the mounting bolt on the axel side seem much smaller than the the diameter of the hole on the axel bracket and trackbar maybe 1/8 of inch or a little more. the jeep was brand new and I am the only one who has ever worked on it, it this normal?. My concern is the axel shifting a little over time and screwing up the bracket hole on the axel.
If this is not normal can anyone tell me the the diameter and length of the bolt so I can pick up a larger bolt on my whay home from work today. I'm at work now and don't have my Jeep with me or I would do it myself.
thanks
AL
thanks
AL
thanks
AL
thanks
AL
This is what happened to me. Wallowed out both mounting holes front and back. I had to weld grade 8 washers and switches to 9/16 shouldered bolts. Much better now. Why jeep didn't use shouldered bolts is beyond me.
