Trackbar relocation and dropped pittman arm
For a 3" lift; 1)Should I be installing a trackbar relocation bracket kit? 2)Will I need a dropped pittman arm for proper steering geometry?
Thanks in advance,
BURNDOG RUBICON
Thanks in advance,
BURNDOG RUBICON
DO NOT install trackbar relocation brackets on the AXLE end of the trackbars (front or rear), unless the stock bracket gets reinforced somehow. A lot of people have had the stock trackbar mounts rip off the axle tube because of the added stress.
Front: I'd recommend an adj. trackbar
Rear: Either an adj. trackbar or a FRAME mounted trackbar relocation bracket
Also, adj. upper control arms will allow you to adjust your caster which should also help the steering geometry for a better ride.
