Traction control after lifting
Anyone have any idea why the traction control/bas light is on after installing 4" lift and 35's. Traction lamp can be turned off but comes on automatically when ignition switch is turned to on position. BAS lamp stays on. Any ideas?
Do the steering wheel dance and turn it off. Won't work right with the lift and large tires anyway. http://www.jpmagazine.com/techarticl...tem/index.html
I had this because of the "wiring being cut" problem. Fixed it with my wiring but also learned something else.
Some jeep sensors are more sensative than others. This means that some jeeps have problems with the computer after lifting, even though most do not.
This is the same problem that Toyota Tundras have. Some of those trucks, even with a small lift, get the computer warning and traction control intervention - on even slow turns. The dealer told my friend that the only fix was to remove his lift, or buy another truck and hope it doesn't have the problem.
Same with jeeps? I don't know. My JKU works fine with more than 5" of lift and 38" tires. I don't have any computer lights and the system doesn't activate during any normal driving...
