Traction Control Locking Up
Old Mar 3, 2020 | 09:13 AM
Mr.T's Avatar
Community Favorite
Originally Posted by Giles Donnell
This is really interesting! I will definitely check my pads out tonight, but do you think it could be the pads when I am only hearing the slight grinding while decelerating in gear? It seems to only happen when the car is naturally engine breaking itself and comes straight from under the shift hood.
That doesn't sound like brake pads, but checking them is cheap insurance. Edit: Check the joints on the rear drive shaft, those might make noise on deceleration that sounds like it's under the shifter.
Old Mar 3, 2020 | 10:37 AM
resharp001's Avatar
Loved
Community Favorite
As soon as Karl mentioned the grinding being brakes earlier, it all hit home. I've had that happen before where the ABS completely locked me up, and that is exactly how I'd describe that noise, as brakes grinding. I'd bet money that was it once I recalled that incident I had.
Old Mar 8, 2020 | 07:22 AM
barongan's Avatar
The symptoms point to the steering wheel not being quite centered or you've got a wheel speed sensor that is indicating a problem- whether it be the sensor or the front hub is another thing.
+1
