Traction control problem?
Old Oct 9, 2011 | 01:21 PM
mook8651's Avatar
Default Traction control problem?
Just installed 2.5"RK lift an running 35X12.50 trail grapplers... Going to have wheel alignment done Monday but here's my problem when I turn the wheel left the traction control goes crazy an the ABS come on an the brakes keep pulsing on an off an when driving on a straight road the brakes go on an I'm driving with the brakes on... I only put the lift on saturday an haven't driven it hardly anywhere but from the garage at my dads back to my house... Will the alignment fix this or is this another problem all together?
Also did anyone experience this problem an if so what did you do to correct it...
Thanks .... O ya I have 2011 2dr
Old Oct 9, 2011 | 01:30 PM
Cdyspeed's Avatar
Is your steering wheel straight?
Old Oct 9, 2011 | 01:33 PM
mook8651's Avatar
No it's turned to the right to keep it straight going down the road but like i said I'm taking it to the alignment shop trm
Old Oct 9, 2011 | 01:36 PM
Cdyspeed's Avatar
That's your problem, you could adjust it yourself if you wanted
Old Oct 9, 2011 | 01:43 PM
Cdyspeed's Avatar
I'm on my phone but I think there is a write up on project jks site to straighten your steering wheel if not let me know and ill post up a pic of what u need to loosen and turn
Edit: I found it all you need to do is recenter your steering wheel and your esp and stuff will go off
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Oct 9, 2011 | 01:47 PM
mook8651's Avatar
Ok thanks... Why would the traction control be going on like that an the brakes keep pulsing on an off tho?
Old Oct 9, 2011 | 01:52 PM
Cdyspeed's Avatar
I'm guessing it thinks your about to wreck. Mines came on before because it gets so windy here. Even if you take Sharp on ramps they can come on I've had that happen.
Old Oct 9, 2011 | 01:55 PM
mook8651's Avatar
Yea I live on some real windy roads an hills an just when it was stock going like 30-35 round bend it would come on an do that .... But thanks foe the info man
Old Oct 9, 2011 | 01:56 PM
Cdyspeed's Avatar
No problem man
Old Oct 9, 2011 | 04:02 PM
09SDunlimited's Avatar
As posted before its because your wheel isn't straight and the computer things you're turning even harder then what you are.
