traction control problem
Old Apr 12, 2012 | 06:41 AM
jimbogas's Avatar
Default traction control problem
2012 Unlimited with a 4" lift and 35's. I simply went around a corner last night and traction control warning came on. Felt like brakes were grabbing the right front and would not accelerate. I simply pulled over and shut down and restarted and all seems well. Has anyone experienced this problem?
Old Apr 12, 2012 | 06:51 AM
wayoflife's Avatar
JK-Forum Founder
you need to make sure that your steering wheel is completely centered. also, if you're running anything more than about 30 psi in your tires, let some air out and that'll help as well.
Old Apr 12, 2012 | 07:18 AM
sempermarc's Avatar
Turn the traction control off and don't drive like your'e Mario Andretti. That should fix the problem. Oh, and center your steering wheel too.
Old Apr 12, 2012 | 11:25 AM
ChrisV's Avatar
I had a similar problem recenty but I was going straight and would describe the feeling as a sputtering (jerky) but the engine wasn't really sputtering, just had that jerky feeling like it was running out of gas or something. It went on for about 10 seconds and then the dash lit up like an x-mas tree and the jerkyness stopped. If I recall correctly it was the traction and EBS lights that came on. I pulled over and cut the engine for about a minute. Started up and it was fine for a while but happened again. Long story short it turned out one of the wheel speed sensors went bad. Had the dealership replace it under warranty. Just something to think about if your wheel is already centered.
Old Apr 12, 2012 | 11:53 AM
jimbogas's Avatar
My wheel is centered so everything was fine this morning so will look at wheel sensors. How did you know which one is bad?
Old Apr 12, 2012 | 04:53 PM
JnT's Avatar
JnT
Just disable the Traction control system. Chrysler recommends it for lifted Jeeps and tells you how to do it in the manual. Had mine disabled since last fall, and haven't missed it at all.
Old Apr 12, 2012 | 04:59 PM
scooby snacks's Avatar
I lifted mine last weekend and used an AEV Procal to center the steering wheel. From what I read the TCS is very finiky if the steering wheel isn't dead straight.
Old Apr 12, 2012 | 08:53 PM
ChrisV's Avatar
I wasn't sure which sensor was bad but you can try reading the codes. If one is failing I would expect it to leave a code.
I just took the Jeep into the dealer because it was still under warranty.
Old Apr 12, 2012 | 09:04 PM
Btkillerr's Avatar
I had the same problem 1 time right after I installed my lift, happened while I was driving home on the freeway and the road swung to the right pretty hard. After talking with my brother he suggested I find a nice open parking lot and idle my JK 5 hard turns to the right then straighten it out followed by 5 hard turns to the left at idle speed, then straighten it out. Shut the jeep off for 5 minutes then start back up and drive like normal. He said something about resetting the electronics to the new center of gravity or some such nonsense lol. All I know is that I havent had a problem since.
BTKillerr
Old Apr 13, 2012 | 07:56 AM
ChrisV's Avatar
BTKillerr
Oh how I long for the days when the only electronics in my car was a transistor radio sitting on the passenger seat. Simpler times...
