JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   traction control still going off on turns (https://www.jk-forum.com/forums/modified-jk-tech-2/traction-control-still-going-off-turns-166781/)
JeepDude90 Mar 2, 2011 07:35 PM
so ive lowered the tire pressure in my tires. i played with the collar on the drag link. i did notice my steering wheel is just slightly off to the left. could this be the problem still?
u-joint Mar 2, 2011 07:38 PM
Just out of curiosity, how fast were you traveling, and what was the recommended (not limit) speed for the turn?
I joke with my wife that those little yellow recommended speed signs are "Jeep speeds"... but seriously though, I would stay at or below those recommended speeds if your Jeep is raised and on bigger tires :thumbsup:
Just a thought... your issue may be something else entirely, but this is something that always crossed my mind when I see threads about traction control issues. :dontknow2:
JeepDude90 Mar 2, 2011 07:44 PM
well like on off ramps. it wont happen if i turn to the right, but it happens if i turn to the left. i can be going like 30 and it will do it
nthinuf Mar 2, 2011 10:30 PM
Steering wheel position has no bearing on what the computer thinks is centered.
Using a ProCal is the easiest way to see the computers opinion on it, which could easily have your steering wheel 20 or 30 degrees off-center to either side. If you don't have one, it will just be a lot of trial and error. Or, you could always replace whatever is bent. :brows:
© 2026 MH Sub I, LLC dba Internet Brands
