trailer hitch
About 30 minutes to an hour if you take off the bumper first. There is also a little weld that stick out on the frame. This will cause problems if you don't smooth it out first with a file or grinder.
Are you serious?? It took me 5 minutes...it bolted right in just like the tow hook. Maybe another 5 minutes to plug in the wiring harness and route it down to the hitch.
Yeah, I didn't remove the bumper at first and had a problem lining up the holes due to the little bead of weld sticking out on the frame. After I removed the bumper and filed the weld down It took a bout 5 minutes then I had to reassemble the bumper. I messed around with the little weld thing for a long time before finally getting it knocked off. I guess I'm just stubborn.
Hello All,
I had called my local dealer and asked how much time was required to install a hitch and harness .The dealer quoted me 3 hours and I almost fell out of my chair ! does anyone have the book time on a hitch install , I would love to Know..
Thanks in advance
HunterBug
Thanks in advance
HunterBug
Hello All,
Thanks in advance
HunterBug
Thanks in advance
HunterBug
That is ridiculous!! There are 4 bolts I believe...no holes to drill, just hold it in place and insert the bolts.....unless you run into a problem like Robar did, but even still..I wouldn't pay for 3 hours labor.
