Trailhead deflators?
Old Jun 28, 2013 | 11:46 AM
JKingAround's Avatar
Default Trailhead deflators?
Anyone use these and do you like them?
Old Jun 28, 2013 | 02:00 PM
Bump......
Old Jun 28, 2013 | 03:39 PM
Twinkydog's Avatar
I use the Smittybilts. Three of mine work really good, one of them probably needs cleaned and adjusted. I like them, just screw them on and let them go. Most of the time, I can start back at the first one I put and start taking them off and doing a fine pressure adjustment right after putting them on.
Old Jun 28, 2013 | 03:49 PM
Bhealey28's Avatar
I've found that the stock key works awesome
Old Jun 28, 2013 | 05:58 PM
I have the tool to remove the shrader valve. I just thought the oasis trailheads was a good set up with the psi being set with an Allen. I figured someone must be using them
Old Jun 28, 2013 | 06:02 PM
MtraXX's Avatar
I borrowed a set from someone the other day and they were pretty helpful! Screw them on, walk away, come back in a few minutes and verify with a gauge and your all set!
Old Jun 28, 2013 | 06:06 PM
I was reading you can drive with them on. Then take them off after they stop airing down.
Old Jun 28, 2013 | 07:09 PM
kh202's Avatar
Yes you can. I love mine!! I can set the to 5,8,11,12 whatever in about 30 sec
Old Jun 28, 2013 | 07:35 PM
Hskr4x4's Avatar
You can't go wrong with them!! I had the arb setup (nice but have to work on one tire at a time), then I had stauns (IMO they are overrated crap) I think the trailheads are top notch
Old Jun 28, 2013 | 07:39 PM
Sirtreysif's Avatar
Valve core remover tool and a tire gauge. Have all four done in less than 5 minutes and save some money.
