Trans Cooler
Old Apr 13, 2008 | 08:54 PM
nukeman's Avatar
Default Trans Cooler
Anyone here installed a trans cooler on their JK? Any recommendations for brand/model?
Old Apr 14, 2008 | 12:59 AM
ronjenx's Avatar
Do you mean an additional trans cooler?
Old Apr 14, 2008 | 04:09 AM
nukeman's Avatar
Yes, sorry.
Old Apr 14, 2008 | 07:27 AM
poppakristof's Avatar
I don't think there is a transmission cooler on the JK from the factory.
If you look you will find a forum about a chime while climbing a hill.
As far as I know, there is not a kit made specifically for the JK's.
But a small cooler has been added to some rigs.
Old Apr 14, 2008 | 08:43 AM
tgrt's Avatar
Former Vendor
I wrote this note down from a previous thread:
B&M SuperCooler #70268
I cannot assert anything about it, but I probably jotted it down in OneNote for a reason.
Old Apr 14, 2008 | 08:45 AM
Dayton's Avatar
Additional? There is NO transmission cooler on the JK.
Nukeman, pm Offtopic for her writeup on the Trans Cooler she installed late last year. Also, Trailbud installed one after his Trans went South.
Old Apr 14, 2008 | 08:54 AM
AZJeeper's Avatar
Community Favorite
If you are talking about a manual transmission, you are right.
However, the bottom 4 inches or so of the A/C condenser is in fact an auto transmission cooler. Follow the lines from the driver's bottom side of the condenser coils (the "radiator in front of the radiator") back to the transmission. I had a transmission specialist look at putting an additional cooler on and his recommendation was to NOT interfere any more with the air flow in front of the Jeep. Maybe a pusher fan, but nothing that would cause an obstruction. If you could locate another place to put a transmission cooler, I'd be interested in seeing your setup, providing it's protected from water (if there's a fan) and trail hazards (if mounted in a place where it's exposed, like the bottom of the JK).
Old Apr 14, 2008 | 10:03 AM
Dayton's Avatar
Originally Posted by Puddlz
We know about those coolers, especially when the guy with stock 4:10's blocks the trail too,
Ouch... well, I could have just kept going and then started ANOTHER OC fire.
Old Apr 14, 2008 | 10:07 AM
RotorHead's Avatar
I bought and installed one of the Summit Racing brand coolers. It was fairly inexpensive and I haven't had any problems. I installed it in front of the ac condenser.
It is true that the JK, at least mine, has a cooler already. It uses the bottom of the ac condenser, but I wanted a dedicated cooler, especially since I tow a camper.
Old Apr 14, 2008 | 10:18 AM
Dayton's Avatar
EVAP CAN was relocated though, I thought.
Details... yes it is.
