Transfer Case Gearing
Old Aug 16, 2010 | 11:38 AM
JKCliff's Avatar
Default Transfer Case Gearing
Is anyone making a set of gears for the transfer case on the X model? I'd like to re-gear to a 4-1 or 5-1... Could the gearing from the Rubicon transfer case be put into the X-model...?
Old Aug 16, 2010 | 12:53 PM
Vernnz's Avatar
All the transfer cases aren't the same? Have you heard of Atlas? Some of their transfer cases allow 2-Lo. The FRONT 2!!!
Old Aug 16, 2010 | 01:33 PM
nthinuf's Avatar
Haven't heard of any tcase re-gear kits.
Atlas (2k+)
Advance Adapters RubiCrawler (auto's only, about $1600)
TeraFlex has a 2low kit that allows seperate 4wheel low and 2wheel low options.
Or
Just swap in a rubi tcase. (cheapest option, watch for someone upgrading to an atlas)
Old Aug 16, 2010 | 01:48 PM
Smopho's Avatar
There is a kit to replace the JK's sector plate in the transfer case and provide you with a 2-lo option. Perfect for backing or parking trailers.
Old Aug 16, 2010 | 02:02 PM
redx08's Avatar
No to both questions. Wish they would come out with something where we could regear the transfer case to 4:1, but I don't see that happening. Best bet is to try to find a used rubi tc or spends big money for an atlas II.
Old Aug 16, 2010 | 03:25 PM
CDavisJK's Avatar
Even a Rubi housing is expensive. I plan on skipping the Regear and just getting the Atlas 10.34 for my 6-speed.
Old Aug 16, 2010 | 04:41 PM
Marshall's Avatar
If your running an auto check out the Rubicrawler!
Old Aug 16, 2010 | 04:48 PM
nthinuf's Avatar
Look around and you can find them used for $650-800. Sure beats the other two options.
At $1600, spending a little extra for an Atlas might be the better option.
Old Aug 16, 2010 | 05:07 PM
Alec's Avatar
I believe the Teraflex 2 lo kit is only for the Rubi tcase.
Old Aug 16, 2010 | 06:06 PM
redx08's Avatar
I think the rubicrawler is great if you have a rubi t case already. With a rubi crawler in the 241j it gives you the option of 2.72:1 or about 7.4:1. I think the 7.4 would be good in some situations, but would be to low of a gear in most.
