Transfer case Gurus
Old Mar 15, 2009 | 11:43 AM
mkjeep's Avatar
Default Transfer case Gurus
Does the frt TC output flange in the frt have any at all type of play in it? I mean mynute play. I can spin it freely, but there is a very tiny amount of play that I can move up and down if I try hard. Probably 1/64 or smaller.
Old Mar 15, 2009 | 12:08 PM
BlackNorthernJK's Avatar
...I'm at work right now, but I'll go have a look at mine later and see if I have any play...I'll let you know how mine is if that helps
Old Mar 15, 2009 | 12:10 PM
mkjeep's Avatar
Cool, I do have my frt ds off though, didn't feel any play with it on.
Old Mar 15, 2009 | 12:14 PM
I'll be checking with mine on this time around...will be ripping the front axel out to regear in a few days though, could let you know how mine is without ds on then....
I have the 3" BD lift and also question the integrety of our bearings with the angles we're running
Old Mar 15, 2009 | 12:16 PM
mkjeep's Avatar
Sounds good I'll be running without a frt ds for awhile anyway
Old Mar 15, 2009 | 12:59 PM
RCJeeper's Avatar
I was under my JK on Thursday night changing my front DS from the original to a replacement stocker that I bought as a trail spare. The reason I was changing it was that I had an ultra annoying rattling sound coming from the t-case. It would start rattling (like a bag of rocks on top of a skid plate) around 45 mph and get progressively louder. Going down a straight highway it would be rattling then I'd shift the t-case into 4x4 and it would go away until I let off the gas. I took it to the dealer and they replaced the t-case under warrenty. I didn't really expect them to warrenty it, but they did. Anyway the sound came back within a day or so. Depressing.
That's the reason I decided to replace my front DS with the trail spare. The spare was brand new and my DS accordian boot was torn by the skid plate.
So I got the DS off and I grabbed the front output flange of the t-case to check for play and sure enough, it had about the smallest amount, maybe .015" on the flange face, up and down. I figured that is the source of the rattling. Put the new front DS (trail spare) on and low and behold, no more rattling on the fwy. I'm assuming the old DS was pretty battled up from hitting the skid plate and it too had a little bending slop. I bought that trial spare on ebay about a year ago for $50 or so. Shoulda replaced it a long time ago.
In answer to your question, yes, mine has a little slop.
I also took the plasma cutter to the skid plate and made a big cutout to clear the driveshaft when the axle flexes down.
Old Mar 15, 2009 | 02:01 PM
mkjeep's Avatar
Thanks for your input, went to go put my stocker back on, which is stll in good shape and was missing one of the upper stock flange bolts The ones for the je reel shaft are not long enough for the stocker, gonna pick one up tomorrow at the dealer and put the stocker back on and see what happens.
Old Mar 22, 2009 | 10:30 AM
Just to give you an update, I found no discernable movement at all....sorry
Old Mar 22, 2009 | 12:30 PM
RedneckJeep's Avatar
Yeah, but you ain't got the forearms mkjeep does. He was probably movin the damn Jeep around when he was doin it.
Old Mar 22, 2009 | 12:35 PM
mkjeep's Avatar
I was pushin and pullin really hard, sent my d shaft back , it was too short.
