Transfer case leaking after installing coast ds
Old Jun 27, 2012 | 01:31 PM
mighty-banana's Avatar
Default Transfer case leaking after installing coast ds
After installing my rear drive shaft I noticed my transfer case in leaking. I removed it and inspected the seal just in case I pinched it or something and no it looked good. my question is can my angle from the pinion cause my drive shaft to vibrate and case the leak. I took it so the angle can be adjusted with upper control arms before I installed the DS. I do believe I feel a vibration or something at take off but then it settles down. How hard is to adjust the angle. Is there a write up on how to do this. Could there be another reason my transfer case is leaking?
Old Jun 28, 2012 | 07:58 AM
Bump can anyone help
Old Jun 28, 2012 | 08:36 AM
maly84's Avatar
Mine was leaking a bit when I did new shafts. Turned out the new yoke had some trash on the splines and wasn't getting a good seal in the t-case. I pulled it, cleaned it, and made sure it was seated properly. Haven't had any more problems. Hopefully your problem is as simple as mine.
Old Jun 28, 2012 | 09:20 AM
Thanks I'll try this
Old Jun 28, 2012 | 11:21 PM
GunDude's Avatar
Seems like I remember reading that you need to put a silicone sealant on the yoke splines. Did you put a new yoke on?
Old Jun 29, 2012 | 07:08 AM
No but since I am going to check if it's clean I will add the silicone sealant. Thank you
Old Jun 29, 2012 | 09:30 PM
This may sound dumb and probably is but where and how much silicone sealant should be used.
Old Jun 29, 2012 | 11:57 PM
Incognito's Avatar
Here's a driveshaft install video where he applies silicone at 1:25, 1:55, 3:55, and 4:25.
http://www.youtube.com/watch?feature=player_detailpage&v=***********
