Transfer Case Lowering??
Old Mar 18, 2010 | 12:27 AM
arkain04's Avatar
Veteran: Navy
Default Transfer Case Lowering??
I am swapping out lifts and have been looking at 3" to 4" kits.
Some come with transfer case lowering kits, some don't..
Is there a reason I should or should not lower the transfer case????
Does it matter if I do not? (early wear issues or whatnot)
Old Mar 18, 2010 | 04:16 AM
mkjeep's Avatar
Do you have a TJ or a JK???? The way the jk is setup, you don't lower the transfer case on any lift.
Old Mar 19, 2010 | 08:13 PM
arkain04's Avatar
Veteran: Navy
I have a JK.
I was looking at lifts labeled for the JK and black diamond lift
stated it came with transfer case lowering equip.?
Maybe I misunderstood.
Old Mar 19, 2010 | 08:21 PM
mkjeep's Avatar
I have a JK.
Maybe a misprint, no transfer case lowering kit is made for the jk.
Old Mar 19, 2010 | 10:06 PM
arkain04's Avatar
Veteran: Navy
Well thanks for the info.
Old Mar 19, 2010 | 10:11 PM
wayoflife's Avatar
JK-Forum Founder
lowering a t-case was only done on TJ and YJ's and were just a cheap fix that helped prevent vibrations after installing a lift. the proper way to fix that was to install a slip yoke eliminator, new drive shaft and adjustable upper control arms to set your pinion angle. the JK has a fixed yoke and CV joins on the drive shaft and so you do not need to worry about vibes or fixing them.
Old Mar 20, 2010 | 06:27 PM
arkain04's Avatar
Veteran: Navy
Thanks for great info and explanations. I completely understand now.
Knowledge is awesome.
Thanks.
