Transfer Case Swap
I am gearingup for a Rock Trac transfer case swap into my X.
Is the Transfer Case all that I need? Are all other components interchangeable?
Shifter?
Wiring?
Drive shafts bolt up?
Could it really be that easy?
Shifter?
Wiring?
Easy is a relative term. I swapped the stock case for an Atlas and it worked me hard. I'd recommend you pick up a stubby, flex handle 3/8 ratchet. Those two bolts up top are a true pain to deal with and a 1/4 ratchet just doesn't have the juice. Don't forget about unplugging that sensor/switch in the back of the case before you try to yank it. Be careful with the shift cable and clip. That thing can break fairly easily. And have a good jack. I borrowed a small motorcycle/ATV lift. A plain floor jack will make it interesting. A six pack and a friend will do you well on this one.
Here's a writeup from Atlas. Of course you ignore the shift cable parts, but there may be some useful stuff in it: ht tp://www.atlas-tc.com/install/jk.html
I saw a 241R get swapped on Saturday.
1) Drop out old t-case
2) Pull harmonic dampner from 241R, put on new fixed yoke
3) Pull old yoke from front output shaft, put on new yoke.
4) Mount T-case
5) Mount T-case support
6) Connect D-shafts
The whole thing took 45 mins.
Andy
4) Mount T-case
6) Connect D-shafts
Andy
From post 4 in this 'other' rubi tcase swap thread...
https://www.jk-forum.com/forums/show...sfer+case+swap
I have seen all of these, but my main question still has yet to be specifically answered definitively.
I need answers to this:
Will the yokes interchange?
Will the shifter interchange?
Other than the transfer case itself (and the fluid) will I need any other parts?
I don't think so, but I don't want to assume. The transfer case is on the way and I just don't want to tear it down to find out I need parts.
I have already upgraded my front drive shaft, but won't do my rear just yet.
The other link mentions removing the harmonic balancer and new yokes...Why?
