Transfer Case Swap
Old Jun 17, 2010 | 11:14 PM
dpoelstra's Avatar
Default Transfer Case Swap
I am gearingup for a Rock Trac transfer case swap into my X.
Is the Transfer Case all that I need? Are all other components interchangeable?
Shifter?
Wiring?
Drive shafts bolt up?
Could it really be that easy?
Old Jun 18, 2010 | 12:05 AM
warlord's Avatar
sorry i dont have an answer for you but i do want to know this info as well
Old Jun 18, 2010 | 08:06 AM
dpoelstra's Avatar
guys who have done this swap, please chime in...
I would have thought there would be a write up but could find none
Old Jun 18, 2010 | 08:58 AM
seer1's Avatar
Easy is a relative term. I swapped the stock case for an Atlas and it worked me hard. I'd recommend you pick up a stubby, flex handle 3/8 ratchet. Those two bolts up top are a true pain to deal with and a 1/4 ratchet just doesn't have the juice. Don't forget about unplugging that sensor/switch in the back of the case before you try to yank it. Be careful with the shift cable and clip. That thing can break fairly easily. And have a good jack. I borrowed a small motorcycle/ATV lift. A plain floor jack will make it interesting. A six pack and a friend will do you well on this one.
Here's a writeup from Atlas. Of course you ignore the shift cable parts, but there may be some useful stuff in it: ht tp://www.atlas-tc.com/install/jk.html
Old Jun 18, 2010 | 09:25 AM
dpoelstra's Avatar
thanks...tools and a shop are not the problem.
All i want to know is whether the transfer case is all I need. Does the shifter interchange? Drivelines bolt up, etc...
Old Jun 18, 2010 | 02:01 PM
dpoelstra's Avatar
I know someone knows...
Old Jun 18, 2010 | 02:05 PM
nthinuf's Avatar
I saw a 241R get swapped on Saturday.
1) Drop out old t-case
2) Pull harmonic dampner from 241R, put on new fixed yoke
3) Pull old yoke from front output shaft, put on new yoke.
4) Mount T-case
5) Mount T-case support
6) Connect D-shafts
The whole thing took 45 mins.
Andy
From post 4 in this 'other' rubi tcase swap thread...
https://www.jk-forum.com/forums/show...sfer+case+swap
Old Jun 18, 2010 | 04:07 PM
Benchmark Designs Inc.'s Avatar
When you're swapping tcases, remove the crossmember and allow the t-case to hang down in the back. This allows for easier access to the 2 top nuts.
Old Sep 30, 2010 | 05:27 AM
dpoelstra's Avatar
I have seen all of these, but my main question still has yet to be specifically answered definitively.
I need answers to this:
Will the yokes interchange?
Will the shifter interchange?
Other than the transfer case itself (and the fluid) will I need any other parts?
I don't think so, but I don't want to assume. The transfer case is on the way and I just don't want to tear it down to find out I need parts.
I have already upgraded my front drive shaft, but won't do my rear just yet.
The other link mentions removing the harmonic balancer and new yokes...Why?
Old Sep 30, 2010 | 08:13 AM
TeraFlex's Avatar
Sponsoring Manufacturer
I did this swap, but had 1310 yokes on both t-cases. I didn't install the harmonic balancer, the RockTrac t-case didn't have it. Seems some Rubi's have it and some don't. You should be able to just swap the driveshafts. I had no problems with the shifter. I didn't drop the crossmember, just used a stubby 12point on those top two bolts.
