Transmission fluid
Old Aug 31, 2016 | 09:22 AM
fultonromero12's Avatar
Default Transmission fluid
Let me start of by saying I have read many threads on different forum but I wanted additional input.
My 07 JK Sahara just hit 90k. Aside from installing a transmission cooler and replacing about 2 quarts of ATF my transmission has not had a full fluid flush and replacement. I am reading conflicting arguments about whether or not to replace it at this point. Most say changing at this point might actually cause more problems in the long run with seals and other internal parts. Others say do it or else your tranny will explode at any given moment. What are your thought?
Old Aug 31, 2016 | 09:33 AM
Mark_CuriousTracie's Avatar
Hey so your question is whether you should change the oil or not? Just wanna make sure I understand.
Old Aug 31, 2016 | 10:35 AM
shabbernigdo's Avatar
changer it. the detergents and such do have a life span and oils do begin to degrade over time
Old Aug 31, 2016 | 11:48 AM
MikeRM's Avatar
I would at least drain the pan, change the filter and re-fill.
Old Aug 31, 2016 | 12:19 PM
jchappies's Avatar
Do not do a reverse flush, take it to someone that will drop the pan and let all the oil out and replace the filter.
Old Aug 31, 2016 | 04:29 PM
Leaning towards changing it. I just got a coupon from local dealership for a tranny fluid change for $159, do most dealerships change the filter or just suck it out and refill?
