Transmission noise
Old Nov 19, 2015 | 07:30 PM
Cda55's Avatar
Default Transmission noise
My 09 jku rubicon has developed a noise. It makes from a stop to about 10 mph. However it does it with the t case in neutral sitting still too. When going from park to drive or reverse it makes it also. It sounds like a clicking noise for a few seconds. I have video of the noise but i dont know if i can upload it on here. Any ideas at all?
Old Nov 19, 2015 | 07:47 PM
Cda55's Avatar
It has 81k miles on it. It has 35's with a small lift. I have only owned it for a few months but never noticed the noise before
Old Nov 19, 2015 | 09:40 PM
brankz's Avatar
Check the tranny fluid......
I had to rebuild the transmission of my 2 door jk ones so I'm paranoid with any transmission noise lol
Check fluid also the for leaks etc
If the sound is when you shift gears that can be a solenoid and that's normal nothing to worry about good luck
Old Nov 19, 2015 | 09:42 PM
brankz's Avatar
Edit on my post..,,,. That's a solenoid noise perfectly normal My 08 2 door had it and my 09 4 door has it tho Don't worried
Old Nov 20, 2015 | 07:55 AM
Cda55's Avatar
It does sound like a solenoid when shifting into drive or reverse. If i drive beside a wall i can hear a rattle almost like a clicking noise. A bb in an empty paint can. Very tinny sound like a heat shield. Fluid doesnt stink more that normal, no leaks and its full.
Old Nov 20, 2015 | 07:11 PM
brankz's Avatar
My 2 door had the same noise before I rebuild the transmission...
Wait no edit even after I rebuild the tranny I still had the same noise after driving for some time
Check the driveshaft
Old Jul 1, 2022 | 02:57 AM
Stiletto's Avatar
ReSharp001 thanks for your input
being a manual transmission i was told anything bad anywhere in the drive line would resonate up through the gear shifter. We hear the noise mostly in third but it happens in all gears. (Sorry if I wasn't clear on that) again thank you for the input. the hunt for the noise continues. Lol
