Transmission swap
Old Sep 29, 2009 | 09:40 AM
MikeReo's Avatar
Default Transmission swap
I have searched the forum and have not found anybody that has swaped a manual tranny into thier auto JK. How difficult is this to do? Not the actual swap which I'm sure could be done in a day or so....but can it be made to work with the can-bus? I would really love to do this but havnt seen anybody attempt it. I am assuming there are no plug and play kits available and I guess the transfer case would need to go as well. Any insight would be great
Old Sep 29, 2009 | 08:55 PM
MikeReo's Avatar
......nothin?
Old Sep 29, 2009 | 09:23 PM
wildandwillin's Avatar
Maybe in the extream section???
Old Nov 13, 2009 | 02:26 PM
bostonMA's Avatar
Anybody have any info on this. What would the cost be? Would one need an adapter for the t-case / are the output shafts different?
Old Nov 13, 2009 | 02:52 PM
NE Wrangling's Avatar
This wouldn't be impossible to do but you would need to first find the tranny. The computer would need to undergo flashing. Input shaft I believe is the same for Auto and Manual on the t-case.
If you were to do this you'd need a new center console where the shifter sits as most of the componets are in different locations. You might even need some additional bracketry to move everthing in it's proper place.
Old Nov 13, 2009 | 02:57 PM
rbrutzman's Avatar
And your head examined for the eventual unforseeable unavoidable problems.
Old Nov 13, 2009 | 03:27 PM
RedneckJeep's Avatar
It ain't like swappin a Muncie for a Turbo 400, that's for sure.
Old Nov 13, 2009 | 03:52 PM
Flash1034's Avatar
Just reprogram the auto and be happy with it. Usually guys want to dump the 6 spped and get an auto...
Flash
Old Nov 15, 2009 | 08:24 PM
pastorsteve's Avatar
I've never met anyone who wanted to swap a manual for anything. As stated above you'll have way more expense and potential trouble than just selling your Jeep and buying one with a manual.
Old Nov 16, 2009 | 02:46 PM
TINMAN080's Avatar
Unless you have a guy with a manual JK wanting to trade while parked right next to you, forget it. There are a thousand differences and the only way to do it would be with a COMPLETE donor vehicle. Also take ANY warranty you have and hang it in the men's room stall, this will cause Chrysler to excommunicate you....
