Trany temp gauge
Old Mar 28, 2010 | 03:13 PM
Dex1's Avatar
Default Trany temp gauge
Has anyone ran a transmission temp gauge on their JK??
If so, how did you run the sending unit?
did you drill and mount it into the transmission pan?
or does anyone make a pan that already accepts a sending unit?
Thanks.....
Old Mar 28, 2010 | 03:21 PM
ronjenx's Avatar
I bought a new pan from the dealer for around $8, and welded in a bung for the sender.
By using a new pan, which was cheap, I had the thing ready to go for the fluid/filter change. That way there was no down-time for the sender install.
This also makes the next fluid/filter change easier, as the sender can be removed to act as a drain plug.
Old Mar 28, 2010 | 04:27 PM
nangulator's Avatar
Great pics and write-up Ronjenx, I have been thinking of a way to do this and I think that I just found it, thanks
Old Mar 28, 2010 | 04:48 PM
Dex1's Avatar
Hey, thanks man!!! great help.....
Old Mar 28, 2010 | 04:53 PM
Ozzy17W's Avatar
Or you could just buy an Aeroforce Gauge that simply plugs into your OBDII port. It would probably be more accurate as it is reading directly from the Jeeps computer, and besides tranny temp. it will monitor at least a dozen other things.
Old Mar 28, 2010 | 05:01 PM
ronjenx's Avatar
I would have suggested that, but most people aren't too keen on the price.
The pan and gauge will cost only about $50. Plus, it makes the next fluid change a breeze.
As far as accuracy, they both read sump temps. My pan gauge and the AeroForce read within a needle's width of each other.
Old Mar 29, 2010 | 02:43 AM
ripmover's Avatar
Why do you need this temp gauge? Just curious.
Old Mar 29, 2010 | 03:14 AM
Yankee's Avatar
Just peace of mind, really. Same reason many like to have voltage, engine coolant temp, etc displays. Especially on modified vehicles.
Heat is a big enemy of auto tranny's. Being able to monitor the fluid temperature, especially while crawling/climbing in hot weather, can let you know you have a problem before it causes damage.
It just might lead you to invest in a transmission cooler!
Old Mar 29, 2010 | 03:26 AM
Dex1's Avatar
A gauge and cooler are a lot less expensive than replacing a transmission!
It just lets you know before you break that there might be a problem...
I also plan to run an engine oil pressure gauge. ( I hate idiot lights!)
Old Mar 29, 2010 | 03:30 AM
RedRock GatorRaider's Avatar
One thing to consider....
I purchased my Aeroforce for $220 shipped. Given that it can do almost all the same things that a procal can do (Set tire size, gear ratio, turn off sway bar light, etc.) you can save $150 by not having to buy the procal. That makes it really just $70 for the Aeroforce.
And you end up with a badass gauge.
