Trektop Question
Once installed is it easily removed? That is, if I want to quickly take it off my Jeep do I need to unscrew things and remove other pieces? I'm looking at the Trektop as a quick way to swap the top during the summer.
yes. so long as you don't need to take off the door surrounds, you can take it off and bundle it up in minutes. reinstallation is the same especially if it is sunny and hot out. like any soft top, in the cold, it can be a PITA.
The Trektop comes with its own door surrounds (more like bars). Before putting the Trektop on, you will need to remove your factory door surrounds and put in the ones that come with your Trektop. I don't see a need to ever take the new ones off once they're on. The Trektop comes off easily, mostly just velcro and undoing the lips just like on the factory soft top. The only thing you have to unscrew is the headliner up by the windshield, which is fast and easy.
I have had the top on, off, rolled back half way, rolled back all the way. I just leave the surrounds on. They are not too noticeable when the full doors are shut and the top is off. Very low profile. I also detach the header from the top and then reattach to the windshield to store it when I have the top off and folded up in the rear. I leave the header attached to the top when I just roll it back.
Who said jeeping was easy ;-)
Thanks!
