Trimming vs removing the stock air dam
Old 05-12-2011, 05:43 PM
  #21
Boat's Avatar
I just took mine off when I went to the 35's rather then trimming it. I like the looks of it. I seen one torn off when the Jeep was trying to get unstuck in the mud and when the Jeep went in reverse the airdam acted like a shovel....well.....a weak shovel.
Old 05-12-2011, 07:54 PM
  #22
medic_23387's Avatar
Just take it off. It will not change any MPG's, looks better and if you ever actually use your jeep you will rip it off anyway.
Old 05-12-2011, 09:45 PM
  #23
raidue's Avatar
I trimmed mine on day 2 running my 35s using an angle grinder and hack saw and went over with a file after to smooth the edges.
The tires rubbed with any flex at all.
Old 05-13-2011, 05:03 AM
  #24
MarbleheadGuy's Avatar
Trimmed the wings off with some tin snips last night. Took less than 10 minutes. No more rubbing. That's what she said.
Old 05-13-2011, 03:26 PM
  #25
mrlobaloba's Avatar
I trimmed mine using a sharp razor knife/box cutter.
Cut like butter
Old 05-13-2011, 04:17 PM
  #26
Matador's Avatar
I trimmed mine first....but then ended up removing it.....
if you leave it on....you can always remove it this way....this was a stock rubi on one of our trail runs last year....
http://www.youtube.com/user/Matador0.../9/_WMxo33tHco
Problem solved!!!!
Old 05-13-2011, 05:14 PM
  #27
Sierra Tango's Avatar
Dremel and a cut-off wheel to remove the wings. Big rock to remove the rest of it. Skip the dremel, just use a rock.
Old 05-13-2011, 05:33 PM
  #28
Enzo's Avatar
Originally Posted by 08yellowx
Rip it off, it's not doing you any good!
You really thing it does not do anything? I think it does, if chrysler could save a dollar the would not put it on.
Have you noticed that alot of car companies removed the cigarette lighter and ash tray, 250,000 cars at $1 a lighter, and $40 per ash tray....they save alot of money, plus the labor to install.
So do you think they would install 80,000 jk's a year with it, plus labor to install it if it does not surve a purpose?
Old 05-13-2011, 10:04 PM
  #29
Jeep(NV)'s Avatar
It wouldn't surprise me with the poor engineering elsewhere on our JK's.
Don't give chrysler to much credit! They did give us a mini-van motor....
Old 05-13-2011, 10:28 PM
  #30
JKSupamun's Avatar
Default :)
yup. history has proven that car makers (even with good intentions) don't always succeed... that's what 'recalls' are for
Quick Reply: Trimming vs removing the stock air dam
