Trouble codes... help
Old Nov 26, 2014 | 04:48 PM
tnt008's Avatar
Default Trouble codes... help
P0132 O2 Sensor 1/1 Circuit High
P1128 Closed Loop Fueling Not Achieved - Bank 1
Also got O2 Sensor 1/1 Circuit Low, Cylinder 6 misfire, and Multiple cylinders misfire, although they all cleared
The first two, rings in and out. May be in for a day or two, then clear for a day or two.
Any advise, or diagnostics?
Old Nov 27, 2014 | 10:25 AM
tnt008's Avatar
Nothing? Nobody has this type of knowledge?
Old Nov 29, 2014 | 01:20 PM
tnt008's Avatar
Final bump on this. Anyone?
Old Nov 29, 2014 | 01:45 PM
Mr.T's Avatar
Community Favorite
For P0132, the electrical diagnostics manual lists several possible causes (electrical shorts, opens, bad PCM, and bad O2 sensor) and tests -- too long to plagiarize here. Given you probably want a quick fix to try, suggest replacing the bank 1/1 O2 sensor. BTW, The P1128 code is likely the result of P0132.
Best of luck
Old Nov 29, 2014 | 02:00 PM
Mr.T's Avatar
Community Favorite
BTW -- The bank 1/1 O2 sensor is on the passenger side and on the upstream side of the cat.
Old Nov 29, 2014 | 02:02 PM
tnt008's Avatar
But theres more then one O2 sensor on the 3.8 ain't it? My understanding is theres two before the manifold, and two after the manifold, but I'm not sure.
Old Nov 29, 2014 | 02:04 PM
tnt008's Avatar
Oh, just seeing this, thanks
Old Nov 29, 2014 | 02:09 PM
Mr.T's Avatar
Community Favorite
There's 4. There's a cat for each bank of cylinders, and a sensor upstream and downstream for each cat.
Bank 1 is the passenger side where #1 cylinder is. Bank 1 Sensor 1 (1/1) is the upstream sensor on the passenger side. 1/2 would be the sensor downstream of the cat on the passenger side.
Old Nov 29, 2014 | 02:19 PM
Mr.T's Avatar
Community Favorite
Same problem here, typing too slow and the reply is late... My motto is that anything worth typing is worth typing two or three times.
Old Dec 3, 2014 | 06:30 PM
Mr.T's Avatar
Community Favorite
Did you make any headway on this?
