Trouble regearing issues with..........
My salesman said that I will have problems re-gearing at an Offroad shop due to the fact that my Dana 30 has electronics for my 4WD to work right. I have a 2011 Wrangler Sport and will be gearing up to 4.11's with my 33' Goodyear MT/R. Will the Offroad shop run into problems puttin' in my gears? Can anyone tell me what he was talking about? He said 15 hrs labor to change my gears when everyone else says around 6 to 8....
Salesman is am idiot. I have a 2011 and there is non problem with an off road shop changing your gears. What he was probably confusing was that the computer will need to be updated with the new gear ratio so that speedometer reads right and shift points are accurate. I am running 35s on my 2011 sport with stock 3. 73 gears and it needs new gears, and dogs going uphill. Check your gears tho cause mine came stock with 32s and 33s should not really need a gear change. The only good luck.
Just a thought if you are going to spend the money to regear I would recommend that you upgrade to either 4.56 or higher. That way or will get better performance with the 33s and not have to regear again if/when you decide to get larger tires. However I regard to you question no there shouldn't be a problem. People regear all the time and it doesn't mess up the 4wd or computer.
