Truck-Lite Installation
Old Feb 18, 2014 | 11:11 AM
iiM RuSHiN's Avatar
Default Truck-Lite Installation
Been looking around and I can't find a written installation instruction. Anyways, I'm about to get a set and I'm wondering if I have what I need to install them. I have a nice set of ratchets and sockets and a set of basic tools (screwdrivers, hammer, pliers, etc.) Also how long did it take all of you to install, and how hard will it be if I don't have a ton of experience but I am mechanically inclined?
Old Feb 18, 2014 | 11:24 AM
White Ghost's Avatar
It's easy pop out the 6 push pins on the grill pull the grill and disconnect the turn signals to get it out if the way( slide the red tabs back to unlock turnsignal connectors. Remove 4 screws per headlight ring and that's it. Also the ring is a little loose on the truck lights so I wrapped 2 rounds of electrical taper around the edge of my TL to make it a snug fit. And put back together. I found the best hight to adjust mine was have the jeep 25feet from a wall and adjust them up to 3.5 feet high
Old Feb 18, 2014 | 11:25 AM
jadmt's Avatar
JK-Forum Ambassador
takes all of 10 minutes. You will need a torx screw driver size 15 IIRC. di-electric grease for the connections and that is it. nothing else needed. If you can tie your shoe lace you can swap head lights. the TL are my best improvement to date.
Old Feb 18, 2014 | 11:27 AM
Rancho's Avatar
Sponsoring Manufacturer
It is a real simple install. It took me about 30 minutes and I had a lot of snow on the grill area.
Use this as a guide.
Truck-Lite Jeep JK Wrangler LED Headlight Installation Write-Up & Testing
Old Feb 18, 2014 | 11:28 AM
Yea forgot to say a t15 torx driver
Old Feb 18, 2014 | 11:31 AM
Also when you plug in your truck lights to the adapter to make sure your pins don't push out because it's such a tight connection mine pushed out a bit and had to push it back it
Old Feb 19, 2014 | 05:51 PM
you get your TL installed?
Old Feb 19, 2014 | 06:22 PM
iiM RuSHiN's Avatar
I haven't gotten them yet. Birthday is next week, hoping my girlfriend is getting them for me if not I'll be buying them myself.
Old Feb 19, 2014 | 06:26 PM
sounds good you won't be disappointed
Old Feb 19, 2014 | 06:31 PM
iiM RuSHiN's Avatar
With everything that I have heard I know I won't and the fact of how disappointed I am with a brand new rigs poor headlights. :/ my 2001 explorer had better lights
