View Poll Results: trusses or sleeves
truss
16
55.17%
axle sleeve
13
44.83%
Voters: 29. You may not vote on this poll
truss kit or sleeves
We have Nitro's pound in's,they do the job.On the other hand truss for the average jeeper who can't weld or makes an attempt to do so,will most likely bend their housing from the welding if not done correctly.Most welding shops can do this with ease,but could get expensive and you have to remove your housing.
Has anyone welded their own truss on. As I understand it to much heat in one place can warp the housing. What's the proper procedure on say the artec truss? I ask cause this is the one I'm interested in.
Why does everybody think Nitro's are hard to install!?! Mine slid in effortlessly, about 12 blows with a hammer. If you prep properly (deep freeze sleeves, clean and heat axle tube) it's one of the easiest mods I've done. Almost easier than wrestling out the springs to put on my TF BB. It's a precise fit for a reason, especially for it to work properly.
The sleeves extend into the housing of the differential next to the axle seal. It's not ending before it gets to the differential as others have suggested. Here are two pictures I pulled from the forum showing how sleeves could have helped:
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=437998"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=437999"/>
But that's just me, I like shit done right.
Sorry man, didn't mean to come off as starting a "flame war". All I'm saying is that IMO sleeves are plenty insurance for probably 90% of the wheelers on here including myself and I wheel "difficult" rated trails in CO. Would a truss be even better insurance? Yes, absolutely, if done correctly. But to be done correctly, it's time consuming and requires some good welding skills and, IMO, way overkill for most of the wheeling most people will ever do. I'd venture to guess many do more harm than good installing these trusses if they aren't following all the precautions in the instructions or jigging.
I went with sleeves because I felt it's all I need really, maybe I'm wrong. It's "good enough" for me but if I were to realize a need to go the truss method, I may just consider a beefier axle assembly with better pinion angle assignment and components all around.
Here are a few pictures of us getting the truss welded on. The key is to go slow and move around on the axle to keep the temperature down. It's really not a difficult install.
With the wheeling we do I didn't even consider the Nitro sleeves but a weld in sleeve would have probably taken care of the job but the truss is just extra insurance.
I agree with the previous post it all comes down to the wheeling you intend to do.
