truss or sleeves ???
Old Jul 22, 2013 | 11:06 AM
jeepwolley's Avatar
Default truss or sleeves ???
hi
I want to start building up my front end for 37 inch tires. C-gussets of course. but what about sleeve or truss what should be first?
just looking for pros and cons on truss and sleeves
thanks
Old Jul 22, 2013 | 11:20 AM
Red Dog's Avatar
If you are going to 37's you will need the C-gussets and the sleeve and Trusses are both great to have if you are climbing rocks. If you just do the dirt roads the C-should be enough. I have the TeraFlex sleeves affordable and not to tough to install.
Old Jul 22, 2013 | 11:24 AM
nthinuf's Avatar
Quite a few recent threads are indicating that a truss would be the better option between the two, but takes a little more effort/knowledge to install correctly. Also, do you have any plans for 35sp shafts? Many internal sleeves don't play nice with the larger shafts.
Old Jul 22, 2013 | 05:32 PM
jeepwolley's Avatar
good point are you aware of any brand of sleeves that are not compatible with that kind of shafts.
Old Jul 22, 2013 | 05:40 PM
Maertz's Avatar
Only nitros allow 35 spline... But on a factory 44 35 splines arent true size of all other 35 splines so prolly nit a big deal. Also only rcv makes 35 spline shafts for the factory front 44
Old Jul 22, 2013 | 06:23 PM
kh202's Avatar
Search around man, plenty of recent threads on this. Short answer, truss adds considerably more strength than a sleeve
Old Jul 22, 2013 | 06:53 PM
Ryan0260's Avatar
Yes, and doesn't limit you on axle choices either.
Old Jul 22, 2013 | 08:58 PM
BRUT4CE's Avatar
Former Member
They both have a purpose that overlaps with the other...
I have sleeves and throwing a truss on as well....truss for lateral strength and sleeves for strength for landing on rocks and slamming tubes into stuff...
Both are best for ultimate strength....
Old Jul 22, 2013 | 10:19 PM
OC-JK's Avatar
That's not true, g2 makes one also. But that's not the point of this thread.
Old Jul 22, 2013 | 10:28 PM
That_guy's Avatar
I'm going with both.. Sleeves are done. Truss is next.
