Tuffy full console
pls forgive this thrashing of a deceased equine. But it has crossed my mind to get a tuffy security full console. Also cubby cover & glovebox. A nice little bit of change for no off-road improvement. (northridge sale...who can resist)
Does anyone here have or has had one and have negative comments??
I do run topless every chance I get and am keeping this toy long term (decades). Cost is not my deciding factor, quality is. Are these products the best out there? Any downsides with these products?
I did a search on this forum and did not find any negatives beside cost. Just giving one more shout out i guess.
I have the cubby cover & glove box. I love them both. I had several cement blocks on the cubby cover all at once, i was a little concerned i might tweak it. It didnt phase it at all.
I would highly recommend both.
I would love the full console, but i simply can't afford the thing. If i can squeak together enough funds someday i may get the insert, but for now Jeep mods are fully on the dream list. If the console is anything like the other two pieces, I think you will like it.
I have the full console. Its truely is a work of metal art.
Jeep should have these from the factory like this. Its a heavy duty steel and powder coated to match the interior. I bought this so I could have a safe place to lock my gun. Long story short, I forgot the key and could not break into this..
I had to wait until I got home to get into it
If someone tries, they will break everything in your JK, but wont get into the console. It has bolts so you can bolt it to the floor. If you dont want to, It can just bolt to the stock locations.
I like that it adds a power source inside the console, You can put your CB inside it and still have room to stash a body. Its freaking big.
The one thing you will notice is the higher arm rest. Its a very nice thick vinyl pad. Its comfortable. it just higher.
If someone tries, they will break everything in your JK, but wont get into the console. It has bolts so you can bolt it to the floor. If you dont want to, It can just bolt to the stock locations.I like that it adds a power source inside the console, You can put your CB inside it and still have room to stash a body. Its freaking big.
check out the PDF, i forgot all the crap it comes with
http://www.tuffyproducts.com/images/...st/157INST.pdf
they would really have to destory the whole thing to get in, With any luck they would make enough noise to be seen.
Its 1 billion times better than the stocker
