Tuner for Penstar
Old Feb 4, 2014 | 09:18 AM
Namtaru's Avatar
Originally Posted by Monte417
No worries about voiding the warranty if you simply return your settings back to stock.
From what I've read about tuners on some other forums, manufacturers can tell if the PCM has been reprogrammed.
Whether or not they actually do anything about it is always the question.
Old Feb 4, 2014 | 09:20 AM
Jeeptang's Avatar
So other then the bullydog having onboard guages, thats the really only thing thats significantly different then the flashpaq....Oh and the GT is pretty pricey
Id be running a 87 tune as well. where i live there isnt any 91 and especially 93.
Old Feb 4, 2014 | 10:08 AM
mattgt5's Avatar
I sold my flashpaq because I couldn't tell any difference. I ran the 93 tune.
sent from my work leash
Old Feb 4, 2014 | 10:21 AM
Jeeptang's Avatar
What did you end up doing after you sold it...You do procal
Old Feb 4, 2014 | 10:33 AM
mattgt5's Avatar
Had a procal. Got the Superchips for beta testing. Have them the feedback they requested. After I regeared, I just didn't feel the gains that others did. Sold it, back to procal.
Old Feb 4, 2014 | 10:40 AM
Monte417's Avatar
You may have very well have read that somewhere but from what I have personally experienced after going to the dealer on several occasions I was told I had messed with my programming. But like you suggested maybe they could tell but didnt say anything. Either way no warranties were voided and that goes for other guys I know who run this programmer as well
Old Feb 4, 2014 | 10:55 AM
mattgt5's Avatar
I will say that I did like the shift points under the tune much better than I do now that I'm back stock.
Old Feb 4, 2014 | 11:08 AM
Namtaru's Avatar
As a side note, when speaking specifically about non tuners like the Procal, i'm surprised the Flashcal doesn't come up more often. It's basically a Procal but with an LCD screen instead of dip switches.
Old Feb 4, 2014 | 11:09 AM
Jeeptang's Avatar
Really leaning toward the Procal... I want to get the little annoying things fixed with the use of oversized tires. Does the procal allow the disconnects to be used in 4hi.
Old Feb 4, 2014 | 11:16 AM
Namtaru's Avatar
If you are leaning towards the Procal, then you should look at the Flashcal. It's cheaper, does a bit more, and has an LCD screen.
