Tuning Fox SS
Old Oct 8, 2008 | 05:25 AM
jayrav's Avatar
Default Tuning Fox SS
Hey!
Before any one asks...no I'm not going to mask any problems I may have right now I just want to experiment for my self how my steering feels after replacing my stock SS. I won't be installing any SS until I get rid of my left side drifting(that is another story)
I'm looking at the Fox SS. I would also be interested in the OME SS, but it is not available as a stand alone.
The Fox SS is tunable from what I have read. I would like to know if anyone here in the forum is using this SS with a set up similar to mines. 3" lift with full set of adj control arms, 35" tires(Cooper STT) with procomp alloy wheel. If so, did you have to discharge it some? If so, how much?
Suggestions are always welcome
Old Oct 10, 2008 | 05:04 AM
jayrav's Avatar
I'm sure somebody here in this forum has a Fox SS with 35" tires. I could definitely use some advice as it relates to tuning this SS.
Thanks
Old Oct 10, 2008 | 05:56 AM
Rescue X's Avatar
I am running a Fox SS with 35's...I did not adjust it from the factory settings and it works great...
Old Oct 10, 2008 | 06:04 AM
Ben Hedrick's Avatar
I am running a Fox SS too. I did have to adjust mine as it came pressurized from the factory and when used as a SS that is a no no. My Jeep pushed so hard to the left that it would have worn out my front tires very quickly. I release all of the nitrogen (air) and now it works GREAT! Now, with that being said, my buddy has the same Jeep, same lift and similar tires and he just put on the dual Rough Country SS setup and he saids that it works like a DREAM! He says that it really drives a lot different and VERY solid. If I had to do it all again I would probably go the Rough Country dual SS route.
Ben
Old Oct 10, 2008 | 08:21 AM
jayrav's Avatar
Ben
Currently I have a RC dual SS, but haven't installed it because I had second thoughts. Not how it performs, but potential wheeling problems. This SS uses a u bolt on the passenger side of the differential(axel) and its also connected to the tie rod and if I hit something with the tie rod that might cause damage to the axel. Atleast thats what it looks like
Sooooo, I'm looking to sell the RC and I'm waiting for my Fox to arrive.
Also, what is the point of the Fox SS if you empty it? You could have bleed it some, but not all
Old Oct 10, 2008 | 08:26 AM
wayoflife's Avatar
JK-Forum Founder
there is no point. honestly, if you can still cancel your order, i would. the fox ss looks great but really is completely unnecessary and if anything - an expensive overkill.
Old Oct 10, 2008 | 12:06 PM
I would agree the FOX is overkill, but it does look goooooood...
And again, I hear the Rough Country is much better and yes it too is overkill...
Old Oct 10, 2008 | 12:11 PM
The shock was pressurized from the factory like a nitro shock and it took me taking all of the nitrogen out to make it not push on the steering. It still works great it's just not pressurized to extend out and push on the steering.
Old Oct 10, 2008 | 02:08 PM
jayrav's Avatar
Hey Ben,
Correct me if I'm wrong, your tires are smaller than 35" and so weigh less and less surface contact then mine which would explain how the Fox SS was pushing you around. The first person to answer this thread uses a 35" tire and was able to keep stock settings of the Fox SS. No bleeding necessary. Which for me I hope is the case since I too use 35" tires.
Old Oct 10, 2008 | 02:17 PM
jayrav's Avatar
I understand, but I really would like to see for my self(no disrespect). Once I have it installed and have driven it on and off road I promise to give you an objective non baised opinion. I'll set my emotions aside and give to you as it is. Whether I like it or not. Take it for what it is worth.
Thanks
