turbo
Old May 8, 2021 | 04:23 PM
landon danser's Avatar
Default turbo
quick question, will a jeep jk(2011) with a 3.8L stock engine handle a turbo?
Old May 9, 2021 | 05:41 AM
Jay2013jk's Avatar
Veteran: National Guard
Community Favorite
Not sure on the Turbo.. I know a guy that has a RIPP Supercharger on his 3.8L..said it really helped, woke it up..
Old May 9, 2021 | 07:36 AM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
If the question is about longevity with the turbo I would say no unless you pull the entire engine down and rebuild to withstand a turbo. That would be studded head bolts, cam suitable for turbo, forged lower compression pistons, connecting rods with improved bearing shells, valve springs changed, higher flow injectors, manifolds for turbo, turbo, intercooler, ECU programming. All in all that is not a big list but I bet you are looking at over $10,000 to do that and that does not include auto modifications if it is the case then add better clutch if manual. That 3.8 is quite a stout engine but the pressures forced induction apply are way more than original design.
You can put a turbo on just about anything - run it hard for a few weeks and it is gone as that temptation to "show" everyone is always there. I know that as I just want to show those cocky JL's/Gladiators that I can spank their asses with my Chev power but I don't. The badges on the side get enough respect.
Old May 12, 2021 | 06:42 AM
wgw's Avatar
wgw
Veteran: Navy
good advice
Old May 12, 2021 | 08:00 AM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Thanks wgw. I try to be neutral and accurate in my advice and leave it up to the recipient for which direction they want to take.
Old May 12, 2021 | 08:16 AM
wgw's Avatar
wgw
Veteran: Navy
yup data is king, retired Ultra Pure Water plant, Waste Plant and Utility Plant operator/manger..its all about the numbers... see too many engine Mods to bump power with no thought to drive train, and lower end issues....
Old May 14, 2021 | 11:26 AM
Jay2013jk's Avatar
Community Favorite
UPDATE.. spoke with my buddy with the Ripp supercharger, 8 years no engine issues.. he did say he broke several driveline components being a JackA-- .. but the engine is fine.
Old May 18, 2021 | 04:21 PM
Plumcrazy's Avatar
I'd be curious to hear how much boost is being run. If engine is healthy and that can be checked with a leadown test, I'm sure it will be fine for a while. Assuming you don't beat on it constantly.
