Ujoint/axle shaft replacement...
Dana 30 front axle...broke mine and don't want to replace with stock (especially since the dealership says it's not on warranty due to my Aussie locker).
Alloy won't be out with theirs for awhile...are there any other options?
I am interested in this also. I would like to put an ARB locker in the front. But Not if I will be replaceing shafts later with different spline count. Are there alloy axles with the stock spline count?
Just to let everybody know. The stock u-joint is not the problem it is the axle ears. Going to a chromoly axle with the stock u-joint will work great.
Also Alloy USA has a 10 yr no questions asked warranty.
David
David
Stock JK not a TJ u-joint.
