Un-even lift question
Old Jun 21, 2007 | 05:43 PM
bim6180's Avatar
Default Un-even lift question
Hi,
I installed my RE BB a couple weeks ago, and just noticed something today. For the rear, the wheel gap between the left and right side is not the same (the pasanger side being a tad higher - more wheel gap).
I assume this is becuase of the shifting of the axle?
Just wanted to hear from the expert out there. If this is the case, i'm not going to worry about anything, since i'll be getting an adj. trackbar soon
Old Jun 21, 2007 | 07:14 PM
bim6180's Avatar
any comment?
Old Jun 21, 2007 | 07:22 PM
rebel's Avatar
Usually the passenger side height will vary, due to the amount of fuel in the fuel tank which is under the passenger side.
Old Jun 21, 2007 | 07:23 PM
schwarzjp's Avatar
Are both springs fully seated in the spacers?
...are the spacers fully seated?
(I'm not an expert...was just a thought)
Old Jun 21, 2007 | 07:24 PM
bim6180's Avatar
Yes, both spacers and springs are seated properly
Old Jun 21, 2007 | 08:14 PM
rubiman's Avatar
did you re-install them?
Old Jun 22, 2007 | 09:36 AM
bim6180's Avatar
I can understand that, but even with full fuel tank, the passanger rear side is still a tad "higher" than the driver side.
Old Jun 22, 2007 | 11:08 AM
JonGiovani's Avatar
What you are experiencing is normal, I have lifted 3 Jk's and so far, every one of them vary in the diffrent corners, both spacer, and spring lifts. Giovani
Old Jun 22, 2007 | 11:36 AM
wipeout's Avatar
I put the exact same lift on my JK and it measures 1/2" difference from on side to other.
Old Jun 22, 2007 | 02:53 PM
bim6180's Avatar
I'll add adjustable trackbar, and report back on the results
