Undo Front Lower Cam Bolts
Old Jan 11, 2014 | 01:01 PM
TripleBJK's Avatar
Default Undo Front Lower Cam Bolts
On a 2013 Jeep Wrangler Unlimited Sport. I currently have a 3.5 rubicon express lift that I did not install. It uses cam bolts to adjust the front lower control arms. I want to upgrade to adjustable control arms or AEV brackets. How do I undo the cam bolt hole? I think the factory mount on the front axle was made bigger for the cam bolt. How do I put the hole back to factory. Hopefully I have this correct. I am no expert but I am pretty handy if I know what I am doing. I hope no welding is involved, I don't know how to weld.
Old Jan 11, 2014 | 02:58 PM
BlackRockBurner's Avatar
The 'ol cam bolt fix. Quick fix is weld washers to make oblong holes return to round holes. That's a lot of lateral stress on a washer that's meant to take compression pressure. If it's a street rig, then washers may suffice. Don't know how long that fix would last. Better fix is cut/ remove and replace lower control arm bracket. I'm not a fan of cam bolts on vehicles.
Installing the AEV drop bracket may take some fabbing to fix that oblong hole.
Old Jan 11, 2014 | 03:30 PM
karls's Avatar
Synergy has a "kit", it's $15. Available most anywhere that carries Synergy products but I've included a link to qtec since they pop right up on google.
http://www.quadratec.com/products/16315_6506.htm
Good luck with your project.
Synergy.com says it's a bolt-on fix, no welding reqd.
http://www.synergymfg.com/Synergy-Su...t-p-30078.html
Old Jan 11, 2014 | 03:31 PM
Aprudhomme's Avatar
I've got the same setup and I was wondering the same thing. I had no idea that you would have to replace the whole bracket to fix this issue. That sucks...
Old Jan 11, 2014 | 03:50 PM
Synergy's fix is good that it's thick metal and butts to tabs, but I'd still weld it in place.
Old Jan 11, 2014 | 03:54 PM
karls's Avatar
Welding is ideal, but synergy *can* be done without welding.....or make things work long enough to drive to a welding shop for extra insurance.
Old Jan 12, 2014 | 07:58 AM
TripleBJK's Avatar
I was afraid this was the case. I am going to try the synergy washers then later get a shop to replace the brackets. Thanks from everyone.
Old Jan 12, 2014 | 08:27 AM
TripleBJK's Avatar
I don't have then factory bolt and nut. Any suggestions on where to get just those 2 bolts and nuts? I see a synergy kit for $80 but I only need to 2. Anyone have the mopar part #? Thanks.
By the way I ordered some AEV brackets.
Also I bought my jeep all done by the dealer. Bad idea. I'm sure I will end up replacing half the upgrades. It's not horrible but the more familiarize myself with my jeep the more I want something a little better. Also I don't always know exactly what was done and I don't have the factory parts that were removed like these bolts and nuts.
Old Jan 12, 2014 | 08:33 AM
A'sJK's Avatar
now would be a good time to get a grade 8 kit and replace all the bolts if u havent already.
Old Jan 12, 2014 | 08:42 AM
TripleBJK's Avatar
You are probably correct. Any suggestions on what hardware kit?
