Upgrade radiator for JK
Old Nov 15, 2008 | 03:16 PM
ReconJeep's Avatar
Question Upgrade radiator for JK
Anyone know of a triple-core, aluminum, or any other performance radiators for JKs. I've been searching around but came up blank. I need something that just bolts on. Any help would be greatly appreciated. Thanks
Old Nov 15, 2008 | 03:48 PM
wayoflife's Avatar
JK-Forum Founder
has your radiator sprung a leak already? if so, i would think you should be able to get that taken care of under warranty. if not, you shouldn't need an upgraded radiator and even if you did, a 3 core isn't necessarily better for cooling. in any case, there are none out there that i am aware of anyway.
Old Nov 15, 2008 | 03:54 PM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
Griffin pro series direct fit hi-performance radiators... through Quadratec! page #262 of their 2008 Holiday Edition catalog, check it out! For the JK $599
Old Nov 15, 2008 | 04:24 PM
ReconJeep's Avatar
Thanks serveapurpose. Experience has shown me that when you run a 8274 on a Jeep across very hot long distances, you need a better radiator. In this case I'm even running a tranny cooler and ac. Something I didn't have in my TJ and it needed the triple core. Made all the difference. JKs may have better cooling but I really don't want to find out in the middle of the Sahara
Old Nov 15, 2008 | 04:32 PM
wayoflife's Avatar
JK-Forum Founder
no way - that's very cool (no pun intended) and griffin makes great radiators - pricey but nice.
actually, if you can mount the 8274 between the frame rails, you won't be blocking your radiator very much and the JK is in now way a TJ, trust me, i still own both and understand your concerns.
Old Nov 15, 2008 | 04:38 PM
33 williys 77's Avatar
Griffin pro series does have the AC condenser but with two 1 in cores.
http://www.quadratec.com/products/51210_221_07.htm
33
Old Nov 15, 2008 | 04:48 PM
Sponsoring Vendor
I wasn't sure on all the specs as I have been back and forth between the fires and JK-forum. My place is about 10 miles due south of the Yorba fire ! So, I am keeping an eye out on that too.
I just remembered seeing it in the Catalog... I think I like it too
Recon where in Irvine are you? I'm off Portola and the 261 tollroad...
Old Nov 15, 2008 | 05:47 PM
ReconJeep's Avatar
I'm just off the 261 and Irvine
Old Nov 15, 2008 | 06:15 PM
Sponsoring Vendor
Right down the way from me! If you see me around say hello... and come and join us at the Suds-n-Grub.
Old Nov 15, 2008 | 06:33 PM
ReconJeep's Avatar
Don't look for me in the JK cause it's overseas. I drive an H3 here. Dark grey, no bling, and with a support the troops ribbon in the back.
Where's the Suds-n-Grub? Is that your place? If it's yours or you work there, I'll take you up on the offer. I'm all for supporting local business. Especially if they wheel
