Upgraded brake lines, Jeep pulls right with moderate braking?
Old Jul 24, 2011 | 07:07 PM
20JK10's Avatar
Default Upgraded brake lines, Jeep pulls right with moderate braking?
When I had the lift installed, I also upgraded to Rock Krawler stainless brake lines front and rear. Under moderate braking [harder then normal but not emergency], it seems the Jeep pulls to the right a little. It's controllable, butt noticeable. I checked the tire pressure, and all the tires are right around 32psi or so.
Any ideas?
Old Jul 24, 2011 | 07:23 PM
single's Avatar
Maybe some air still trapped in your right front line? I'd try bleeding them again.
Old Jul 24, 2011 | 07:41 PM
BKGM Jeepers's Avatar
X2. Bleed the oposite side from your pull. If the front left is what's pulling then re-bleed the front right.
Old Jul 26, 2011 | 08:50 AM
LOST's Avatar
I was having the same issue.
Bled them well after the installing 6" longer lines and 3 weeks later bled them again after it was pulling during braking. Found air bubbles in the left line only. Seems ok now.
Old Jul 26, 2011 | 11:49 PM
KenB1010's Avatar
it doesn't show in your profile what lift you have, but also check your track bars to be sure the axles are centered on the jeep. a slight difference can also cause pulling.
