Upgrading my stock Rubicon
Old Sep 16, 2009 | 08:44 AM
mbernardo's Avatar
Default Upgrading my stock Rubicon
Hello,
What do you say about exchanging stock tires (255/75R17) on my Rubicon for 265x70R17 or 265x75R16? Those are the sizes I am alowed to use in Portugal. At least on these sizes I can get mud tires.
Do you think a lift would help to improve its ability to offroad? Do you recomend what type of lift. I don't want the Jeep looks high with small wheels.
I was thinking a kit of 2'' ou 3''.
I am all opened to suggestions in wheel (steel) and tires too.
Thanks a lot guys.
Old Sep 16, 2009 | 09:56 AM
nthinuf's Avatar
Allowed to use by who? Is it government mandated that you stay with that height? Or is it just the normal recommendation based on a stock vehicle?
255/75/17 = 32.1x10
265/70/17 = 31.6x10.4
265/75/16 = 31.6x10.4
Between those options, I'd stay with the stock height on the stock rims.
If it isn't a government regulation, you can go up to a 33x10.50 with no lift/spacers and maybe minor trimming. You can go wider, but will need more trimming and possibly spacers or new rims with a different backspace. If you want a lift, decide what tire height you want to go to before choosing.
Also browse through the Wheels & Tires area of the FAQ's at the top of this section if you haven't already.
Old Sep 16, 2009 | 12:14 PM
mbernardo's Avatar
I want to have a set of M/T tires to go to rides and have the stock to use everyday.
The rules are made by portuguese laws, but I can pay and have other sizes, even 35'', but I don't want to go bigger than 33''.
The problem is; when I put stock wheels and tires I stay with bigger suspension and smaller wheels/tires, it does look bad or not? Or a 2'' or 3'' lift doesn't affect the ride with stock wheels?
Thank everyone.
Old Sep 16, 2009 | 12:56 PM
porters's Avatar
For a 2" lift 32: tries will look a little small. 33" tries would look ok. Can you do a 285/70/17?
Old Sep 16, 2009 | 01:33 PM
mbernardo's Avatar
That 285/70R17 is 33x10,5 I think and it's what i'd rather but I have to pay an extra to legalize that size... But it's what I am probably going to do.
I've seen many 2'' and 2,5'' very interesting. I would like to have a very confortable ride but also good on offroad with plenty of suspension range.
What do you suggest?
Thank mates
Old Sep 16, 2009 | 01:42 PM
porters's Avatar
285/70/17 are 33X11.5. They should fit on stock wheels without a lift and should not rub. If you add a 2" lift then that would be a good compromise between off-road capabilities, flex, clearance, yet still maintain good on road handling and gas mileage. This is one of the most common configuration people are running for those reasons.
Old Sep 16, 2009 | 02:17 PM
mbernardo's Avatar
I am going to have the M/T tires mounted in steel wheels only for offroading. For an everyday use I am going to ride stock wheels and tires.
Anyone uses Cragar wheels? Are they good?
