Upper control arm bolt lose?
Old Nov 17, 2008 | 11:36 AM
sw0cb's Avatar
Default Upper control arm bolt lose?
Hey y'all, i got under my Jeep the other day and noticed where my passenger side upper control arm attaches to the frame the bolt was all the way unscrewed and nearly touching the cat. I attempted to tighten it back up but once you screw it all the way back in, it refuses to tighten down. Any ides whats wrong? The bolt may be messed up but it dosent look to be possible to remove it with removing part of the exhaust
Old Nov 17, 2008 | 11:41 AM
Robar's Avatar
You would have to cut the bolt out and replace it with another from the opposite side of the arm.
Old Nov 17, 2008 | 11:51 AM
sw0cb's Avatar
Awesome...not. Has this happened to anyone else? Guess im gonna be paying a visit to my local jeep stealership soon to get that bolt.
Old Nov 17, 2008 | 11:58 AM
Bodo's Avatar
The threads are probably messed up. Get a new bolt and nut and do it again but this time use blue loctite. The factory used it on the original bolts. Be sure to torque everything to specs.
Old Nov 17, 2008 | 03:46 PM
jpp's Avatar
jpp
Or take it to the dealer.. Did you loosen it initially, or did it loosen on its own? Should cover under warranty, I would think.
Old Nov 17, 2008 | 08:39 PM
jayrav's Avatar
Even though it may be under warranty, to save time just go buy the bolt yourself. Make sure its grade 8. Trust me its no big deal. This is a bolt that is cut when you upgrade you control arms. BTW, torque spec is 75lbs. Let us know how things work out.
Good luck
