Upper control arms
Old Aug 23, 2009 | 01:05 PM
bwlilly's Avatar
Default Upper control arms
im looking to replace my front upper control arms on my 4 door rubicon. i have a 3.5 inch kit on now and i think i need a few more degrees of cam on the axle. does anybody have any suggestions.
Old Aug 23, 2009 | 01:09 PM
jonmorgan12's Avatar
I would personally go with the adj front lower control arms- you could set your caster with those just fine-
Old Aug 23, 2009 | 01:20 PM
KCTW's Avatar
I'm not sure there's enough adjustment in the front upper control arms. I would get adjustable lower control arms.
Old Aug 23, 2009 | 01:27 PM
nthinuf's Avatar
Uppers are less expensive, lowers offer a better range of adjustability. The Currie uppers are the ones I see posted about that can adjust short enough without needing lowers also. (others may work, I just haven't seen any posts on them...)
I know Mr. Northridge sells some kits with adj uppers only, so that may be a good place to check.
