Upper and Lower Ball Joints....What to do???
Old Apr 16, 2014 | 06:32 PM
  #21
DunnyBunny's Avatar
JK-Forum Ambassador
Originally Posted by Joe_B
The little plastic washer can easily be removed as mentioned above. When reinstalling the shaft just be very gentle as you approach the seal and slowly push down on the u-joint as you twist the shaft. This will help the splines line up and also raise the inner end of the shaft to safely make it past the seal. Don't worry about the stud on the upper ball joint spinning. Just make sure the ball joint is properly seated. Once the full weight of the vehicle is on the knuckle the stud will tighten up and you'll be able to tighten the nut. Just make sure you follow the torque specs. You'll will love the new ride. Next to gears, synergy ball joints are my 2nd favorite mod/upgrade.
Agreed. Much less wondering after putting mine in. Tightened up some and feels great.
Old Apr 18, 2014 | 06:44 AM
  #22
JKjunkie2009's Avatar
Project DONE!!! Everything went back together smoothly, and I have not noticed anything out of the ordinary, besides the fact that I no longer have death wobble and my jeep handles like a dream!!!
I can actually hit bumps in the road now!!!!!
Thanks for all the help gentleman!
Old Apr 18, 2014 | 11:32 AM
  #23
JayswranglerX's Avatar
Nothing like fixing things yourself and getting great results !
Sent from my LG-LS980 using JK-Forum
Old Apr 18, 2014 | 12:10 PM
  #24
FDHog's Avatar
You're lucky.
My stock Ball joints were shot after 12k
The roads were so bad here this winter one of the potholes knocked my Kenwood H/U out.
Replaced with Synergy
Old Apr 18, 2014 | 12:17 PM
  #25
TaylarsJK's Avatar
I have 22k on my OEMs and I'm sensing the need for some Synergy ones. Downtown/college town in Tallahassee FL is rough as hell and I bounce all over the road. Just a little nervous on the labor for the replacement
Old Apr 20, 2014 | 01:07 PM
  #26
Maniacal's Avatar
There is a local shop that are doing mine for 80 bucks! I guess I should be very happy about the price.
Old Apr 21, 2014 | 07:56 AM
  #27
80 bucks?1?1?! What a steal! I had people quote me 150-200 per joint!
Old Apr 21, 2014 | 09:39 AM
  #28
Joe_B's Avatar
It's $450 for all 4 up here in Canada.
A few beers and a few choice words if you do it yourself. It's not too bad of a job
Old May 10, 2014 | 07:45 PM
  #29
GentleGiant's Avatar
Doing mine tomorrow. An 08 with 113K miles and original Bjs. Also going up 3 numbers on take-off springs from a Rubi and adding a 1 3/4 puck.
