urgent help needed
Old Apr 11, 2009 | 06:25 AM
bubbad323's Avatar
Default urgent help needed
Need help! At shop getting new whells and tires mounted. The rims are 16 inch pro comps. They are not sitting tight on the hubs. My stockers fit snug. Is this right?????
Old Apr 11, 2009 | 06:34 AM
Rubidonn's Avatar
Could be the wrong offset... 16's are at the point where the clearance w/the break caliber and so forth get real close... so you may need to either get different rims or get some wheel spacers.
Old Apr 11, 2009 | 06:35 AM
greenamphibious's Avatar
is there a little spacer on the hubs around the lug studs? if so remove them, also check contact with brake caliper, but that shouldn't be an issue
mkjeep's Avatar
Did you take the star clip washers off the studs?
Old Apr 11, 2009 | 06:36 AM
RedneckJeep's Avatar
Get a bigger hammer.
Old Apr 11, 2009 | 06:38 AM
mkjeep's Avatar
Grind the caliper down if it's hitting, but that's mostly on 15" rims
Old Apr 11, 2009 | 06:40 AM
JPop's Avatar
Yep, don't force it, get the bigger hammer.
Old Apr 11, 2009 | 06:53 AM
Offroadme's Avatar
hahaha that is always a great quick fix for just about everything
Old Apr 11, 2009 | 09:28 AM
mmccurdy's Avatar
There is a lot of discussion about "hub-centric" vs "lug-centric" wheels out there... honestly, I never saw the hub as being integral to keeping the wheel on your vehicle or centered (the lug nuts should do that -- make sure you tighten in a star pattern!), so I never gave it a second thought until I saw all this talk on the internets about it.
If I understand your question right, you have a little bit of space around the hub so it might wiggle a bit on the mounting surface if you didn't tighten anything down? I think you're fine. Again, just make sure you tighten down the lugs following a recommended procedure (I usually do the star pattern but not fully torqued while the wheel is in the air, drop the vehicle, then torque them down to about 90 ft-lb) I think I also have the space or wiggle room you refer to, and I've never had a problem at all.
Old Apr 11, 2009 | 09:32 AM
rjhoop's Avatar
thats what ya gotta do!!!!!!!!!
