URGENT help: teraflex front sway bark link install
Old Dec 15, 2012 | 08:30 AM
johncantello's Avatar
Default URGENT help: teraflex front sway bark link install
Hi all, i'm in the middle of installing my 1.5" leveling kit from teraflex. I am having problems with the tightening the upper bold of the front sway bar. The new link came with a nut attached to the top bolt but it just keeps spinning when I try to tighten. do i need to peel back the rubber boot to find a tightening nut??
Old Dec 15, 2012 | 08:41 AM
v8zracer260z's Avatar
Veteran: Marine Corp
I have not done a teraflex but the others I have done have a thin hex head that needs a thin wrench to keep the shaft from turning. Some times an impact driver or an air ratchet will work instead depending on access.
Old Dec 15, 2012 | 09:54 AM
I figured it out. There is a hex nut hole inside the bolt at the end to hold it tight while tightening the nut.
Old Dec 15, 2012 | 12:51 PM
jwilson2598's Avatar
Must be the day for leveling kits, I put mine on today too.
Old Dec 15, 2012 | 02:11 PM
I did the 1.5 spacer kit. Looks good. How about you?
Old Dec 15, 2012 | 07:58 PM
Same kit here. New tires get mounted on Tuesday, can't wait to see how it turns out.
Old Dec 25, 2012 | 08:48 PM
LSM's Avatar
LSM
Just curious if the new sway bar links go on backwards from the factory. I installed mine this past weekend and that's the only way I could see them going according to the directions. Havnt had any problems yet and I love it.
Old Dec 26, 2012 | 06:18 AM
Mine went back in just like the factory ones did.
Old Dec 26, 2012 | 06:26 AM
backcountryislife's Avatar
Mine were the same, I could only get them in upside down.
Not much reason it would matter... but they seem to be just fine still.
