Using 4" lift Sway Bar Links on a 2.5" Lift...Can this be done??
I'm running a 2.5" Coil lift on my '11 Rubi JKU with 1.5" Spider Trax spacers and 315/70/17 Mickey T's Baja MTZ. I acquired a set of sway bar links from a 4" lift. My question is can I run this with my set up? Pro's/Cons. If I'm not mistaken TF 2.5" lifts give you longer sway bar links with the kit. I think your supposed to swap your rear sway bar links to the front on replace with the supplied links Any input is appreciated.
