valve stem mod?
i think that if you are grinding on rocks that far into your wheel, it wouldnt matter what kind of stem you have. as small as a valve stem is, it can only be so strong. an all metal stem would probably just get bent up to hell and even snap off, perhaps causing more issues. at least the rubber valve stem would bend.
I see what you mean about rocks but I was thinking to sticks and small logs. there is one place we wheel often and I always seam to get some sticks stuck in between the tire and rim at the bead. this is what got me thinking about the possibility of having my valve stem torn off.
I would stick with the plastic ones. The metal ones are more prone to snapping right off. Plastic is cheaper and easier to replace. It also flexes a little bit before it breaks off. Metal does not have that pliability.
Or you could relocate the valve stem if you have steelies, there are some "short" stems available out there. Some people fab up a metal plate that protects it or add a beadock system that covers the stem. Google is your friend.
I completely sheared off my metal TPM stem on a rock...metal=fail. The rubber ones could rip if compressed against the rock & rim but they have a much higher tolerance to logs/rocks. Worst case they tear, best case they just bend out of the way.
