Vent Bellow Kit?
Old Nov 26, 2012 | 11:47 PM
crazy09r6's Avatar
Question Vent Bellow Kit?
Has anyone tried or thought about using this for there diff vents?
Vent Bellow Kit [Vent Bellow Kit] : TMR Customs, Custom Fabrication Components for Offroad Vehicles
Old Nov 27, 2012 | 12:30 AM
HeyBob's Avatar
Haven't used it but now curious. My front 30 always looks milky when I swap fluids. Even the first 15k miles when it never went under h2o!
This might be my next mod.
Old Nov 27, 2012 | 12:47 AM
crazy09r6's Avatar
It seals it completely, so as long as the bellow doesn't get ripped I don't see the need to worry about water anymore.
The only concern I have is, would diff not getting fresh cool air be bad for it?
Old Nov 27, 2012 | 03:09 AM
SiliconTi's Avatar
Diff does not need air at all. The breather just allows air to enter/exit as heat expands the fluid (and metal to some extent). These look like a good idea as long as the have enough capacity so they do not cause a vacuum.
Old Nov 27, 2012 | 04:11 AM
crazy09r6's Avatar
Do you think you could use these on the T-case and Trans also?
Old Nov 27, 2012 | 08:59 PM
cmueller's Avatar
I have one of these on my rear axle. Works good and stays put unlike the factory tube and clip. Try an ATV supply for a cheaper one.
Old Nov 27, 2012 | 09:09 PM
crazy09r6's Avatar
Thanks for the info.
What do you think about using it on the T-case and Trans?
